[SOLVED] front panel audio jack not working.
Jan 3, 2020
45
front panel usb is working fine but audio jacks are not working. i have connected audio connector to J AUD. Motherboard jacks are working fine.
Sep 19, 2020
12
Hello,
May I ask which driver have you installed and what are the errors you are encountering? I would recommend that you try the following fixes:
  • Be sure to update the driver to its latest version.
  • Make sure that the audio device is set to default.
  • This might be funny, but you could try any other audio jack in your back panel.
Hope any of this works for you!
Jan 3, 2020
45
Hello,
all backpanel audio jacks are working. front panel is showing in sound control panel but it is showing disconnected like there is no audio device plugged in.
Jan 3, 2020
45
I would recommend visiting the link I provided above, select Windows 7 (assuming 64-bit), expand the Onboard Audio Drivers, download and install the Realtek HD Audio Drivers from there. Hopefully, they will work for your Windows 10 installation.
-Wolf sends
thank you i will try it then tell you
