Question Front panel audio not working properly (only left side is working) Phanteks P400a
Apr 16, 2020
Hi all. Yesterday I built my pc almost from scratch, only re using my 1050ti. My mobo is a x470 gaming plus max and cpu is ryzen 5 3600x. The case, as I stated is a Phanteks Eclipse P400a. Everything is working fine except the audio coming from the front panel. Tried connecting speakers, headphones and earphones and all turn out the same: only the left side works and the right is dead silent. I opened up the pc and checked of the HD audio cable was connected correctly, which it was and did all sorts of software debugging possible, such as messing around with drivers and no luck. Rear panel audio works fine. I can return the case but I do not want to go through the trouble of removing everything from the case unless there is no possible fix. Thanks in advance
