Hello. I bought a new case the Fractal Design Meshify 2 Mini and the front panel audio is not working. If I plug in my headphones windows doesn't recognize it. The headphones work if i plug to them to the rear audio connectors. The rest of the panel is working besides the USB 3.1 Gen 2 which is not connected to my MOBO as it does not support it.
When using my previous case the front audio worked fine. I tried to download the realtek drivers for my MOBO and check the "disable front panel jack detection" then it shows up as another device but when i plug the headphones i don't get any sound.
My specs are:
MOBO: MSI B250M PRO-VD
CPU: Intel Core i5-7400
GPU: AMD Radeon RX 6600
RAM: Corsair 16 GB KIT DDR4 2666 MHz CL16 Vengeance CL16-18-18-35
PSU: MSI MPG A650GF
CASE: Fractal Design Meshify 2 Mini
Monitor: AOC I2481FXH - 24", IPS
Drives:
ADATA SATA SSD for system files
WD SATA SSD
HDD (only for storage)
My specs are:
PSU: MSI MPG A650GF
Drives:
WD SATA SSD
