Hello, I'm trying to set up my front panel audio connection with a Antec Sonata III case on a Gigabyte P55-UD3R motherboard. However, I'm not experienced in doing so and something seems to be wrong (as plugging in my headphones to either jack in front while audio is playing does nothing).
I do not understand how to use the Pin No./Definition tables given in both the Antec manual and my Gigabyte manual. I've located the pins on the motherboard and plug in the HDA cable (AC'97 does not yield any sound either, and I would rather HDA) so that all pins in the header are in. I looked through the BIOS and did not find anything notable pertaining to audio, other than Azalea codec options. I installed GIGABYTE's drivers and nothing.
Am I overlooking something here? Also, the plug in my headphones seem to fit a bit... err, loosely in the jack, with standard 8mm headphones. Is this normal? Most jacks seem to have some sort of "pop" effect when the phones are plugged in right.
Thanks for any help. This is cross posted to HEXUS.community discussion forums.
