Question Front panel connection plugs ?
Sean_50
32
hi guys, ive just installed a cooling system that required the radiator to be fitted with the fans on the outside of front of case, but the problem is the case plugs that push into the case to fit it don't reach far enough.
Does anyone know of any kind of extender kit to move the front of the case further out or even what these plastic fixers are called ?
Thanks
Sean
The info you've parsed is vague. You might want to mention the make and model of your case, the cooling system you're working with and perhaps images of the issue you speak of to help give us context and perhaps a simple yet prompt answer.
Stand offs...?
