This is my first time encountering front panel connections, I can install Hard Disk, Atx, cpu fan, power supply, Mobo etc. My casing have:
2 PIN H.D.D LED (Orange and White)
2 PIN RESET SW (Blue and White)
2 PIN RESET SW (Orange and White)
9 PIN USB
HD AUDIO
AC 97
i search on youtube and google for the solutions on how to intall but i failed the thing is theres no sign whether its a + or - on my mobo neither on the switch itself so i can't identify where to put them. I do find F_Panel which mean is front panel right? I seem to be confused on why the h.... i got this two RESET SW? What!? I cant find the POWER SW. It seems to work on my other mobo because an I.T install the f panel connections but i want to try it myself too. So the question is how do i know where i put the LED, RSW, RSW? in the F_panel?
My mobo is. ACER G41T-AD, can you elaborate what should i do? I cant seem to find the manual due to low internet connection.
Your answers will be deeply put on to consideration. Thanks in Advance love you guys
9 PIN USB
HD AUDIO
AC 97
