[SOLVED] Front panel connectors on Lenovo is6xm rev 1.0 motherboard
16
I have this motherboard but I'm not sure where I'm meant to put in the front panel connectors, the ones I have are:
H.D.D +/-
Reset Sw
Power Sw
Power LED +
Power LED -
The issue is I don't really know where on the motherboard these would go, hoping someone would help me out here.
its in corner near sata ports
your mainboard has no such front panel pins u need
Placa-base-IS1XX1H-para-Lenovo-ThinkCentre-M900-M700-placa-base-peque-a-AIO-100-probada-completamente.jpg
front io is integrated on top of picture (audio ports, power button, usb)
In the photo you shared your see the motherboard pins (Power SW, RESET sw, HDD, etc) in the Bottom right. It's vertical in your pic. Can you find which pins are for Power SW and Reset SW?
