Front Panel Connectors
Bobberz
12
Hey everyone, Recently I've been trying to build my own computer and have had real struggles when trying to wire it as it is my first time. Thought it'd be easier but really struggling. The problems are :
The CPU connector from the PSU doesn't fit into the motherboard as the connector is an 8 pin ( CPU cable has 2, 4 pin connectors (won't fit together already tried) )
Also struggling to work out how to connect the front panel connectors into the motherboard. I have Power Switch cable which I don't know where to fit. As well as the +P / -P led & HD Audio connectors. The motherboard i'm using is the ASRock H97M Pro4 and the case is the NZXT S340
Any help would be greatly appriciated as i'm new to building computers. Thank you
My build is
http://uk.pcpartpicker.com/guide/3NYcCJ/800-gaming-pc-nvidiaintel
Thanks
Hi, we have all been there, but with a little patiance and thinking you can get everything done in minutes. Well I'm sorry, but I am really bad at explaining things in forums or so. Is there any way we can talk and I can try to help you with whatever you need.
Have you got something we can message on, appricate the help bro. I've got anything really If you've got skype add me : ItzBobberz
Added, accepted, awaiting quests :) it's in my honor to help you! Msg me anytime you want I'll stand by.
