Front Panel extenders for motherboard?
rosiv
I need extenders for my front panel connections so I can connect them when my new GPU is in, for without them, the GPU would obstruct the wires from connecting.
I looked on ebay, newegg and amazon and they were all sold out of the onesuggested to me :
http://www.newegg.com/Product/Product.aspx?Item=2BX-0005-00005
NZXT Cb-Frpan Set 300Mm Individually Sleeved Front Panel Connections Premium Cable (Black)
So does anyone know of any options for me?
Here is a reference image of the area that needs to be connected to:
With the ports ADU1, JUSB2, JFP1, and JFP2 being used.
Here is the picture of the acutal internals, it is very tight.
Here are my specs
CPU AMD A10-6800K
Ram 8.00GB Single-Channel DDR3 @ 798MHz (9-9-9-28)
motherboard MSI FM2-A55M-E33
I suggest you take a look at these:
  • BitFenix - Front Panel I/O - LINK
    BitFenix - Front Panel USB - LINK
    BitFenix - Front Panel Audio - LINK
You will probably need to get 2x or 3x Front Panel I/O for full functionality.
