Question Front panel led not on. Dangerous?
Feb 26, 2019
31
So I built my first pc which took me 1 and a half day trial and error and it works. But the thing is my front panel LED doesn't go on probably forgot to plug it in or did it wrong (sharkoon vg-4w) but I dont really mind that since I find it kinda ugly. Everything on the front panel seems to work can this be dangerous?
Ralston18
Update your post to include full system hardware specs and OS.
Just to be sure: which front panel LED - Power on/off?
If the pc is otherwise working the problem could be either the LED is not plugged in, the connection is bad, the cable is bad, or the LED itself is bad.
Doubt that the situation is dangerous just on the basics alone.
It is just that there will always be some uncertainty about the pc if something does go astray. E.g., you upgrade, add another component, or otherwise make some change.
Go back into your build and doublecheck everything. Do not use "trial and error".
Work through the motherboard's User Guide/Manual along with the applicable documentation for all installed components. Pay attention to the details and fine print.
Front panel HDD and pwr led's are polarity sensitive.
Likely you reversed the + and - leads.
Just switch them.
No harm will come if you get it wrong.
For amusing results I once made a mistake and connected the hdd led to the reset pin.
Still no permanent damage.
