Ok so i do have a xiaomi piston 3 connected to the pc using this adpater :
http://www.amazon.es/StarTech-com-Adaptador-Divisor-Auriculares-Pines/dp/B0058DOWH6/ref=pd_sim_23_2?ie=UTF8&dpID=31WQufvb-jL&dpSrc=sims&preST=_AC_UL160_SR160%2C160_&refRID=03F9TWVQ0ZKK095DC65C&tag=mediavida0c-21
It works as it should. But when using the front panel audio and playing games it makes a static noise all the time ( only playing games ) . Using the back panel would make it work without the noise. Problem is the cable isnt that long enough to reach there while im sitting. What can i do? im kinda lost 🙁 help pls.
PD: is not headphone or adapter fault . i tested with diferents ones and it was happening too .
PD2: only happ¡ens in games.
PD3: I think is the gpu , since i played with intel hd one and it was fine.
