I m using Gigabyte H310M motherboard its back 3.5mm jacks works fine but when it comes to the front panel 3.5mm jack, only audio will be working fine and microphone jack will not work, then i tried changing the audio to microphone to check whether jack is fine or not, but its ok it only picking the voice at all.i have seen several YouTube videos and tried but no change, uninstalled and installed the drivers many times but no change, so can any one me to know, whats the actual problem is? And please give the solution
