Front panel pin header
tashimee
22
I bought a VIA Embedded EPIA-M920-12Q and I am having trouble with where to plug in the front panel connectors.
Motherboard
pin 1 +5VDUAL pin 2 +3.3V
pin 3 +5VDUAL pin 4 SATA_LED
pin 5 PWR_LED pin 6 PWR_BTN
pin 7 +5V pin 8 Ground
pin 9 NC pin 10 -RST_SW
pin 11 NC pin 12 Ground
pin 13 SPEAK pin 14 +5V
pin 15 no pin pin 16 -SLEEPLED
Front panel
reset sw 2 pin connector
power sw 2 pin connector
power led +
power led -
hddled + - 2 pin connector
Could somebody please tell me which connector plugs in where?
My guess would be the following.
pin 2/4 Sata LED (HDD)
pin 6/8 power button
pin 10/12 reset button
pin 7/9/11/13 = speaker (being 7/13 only connected)
pin 3/5 power led
* disclaimer * I am not a VIA technician and I will not be held responsible if your board goes poof into flames or other act of god is bestowed upon your cpu. :)
Thank you for your answer, I can power up the board now. Now I can't get it to look at the hard disks or put anything on the monitor. I am going to take it to the geek squad and see if they can get it the rest of the way.
But I wanted to thank you for your help.
