G
Guest
Guest
Archived from groups: alt.comp.hardware.homebuilt (More info?)
I just installed an ABIT-1C7 MB into an Antec True 430 case/Power Supply.
This novice is now working on the front panel switches with this question
about orientation.
The Abit manual says "Reset (labeled RESET SW) connects to your motherboard
at the RST connector. The label should be facing the front of the case, and
for all of the following connectors as well."
That seems impossible since the label faces Top or bottom since pins 5 and 7
are parallel to either.
Or should I even care since the only explicit warning on this page is "watch
the power LED pin position ... could cause system malfunction.". Fact is, I
see nothing on the POWER SW (the power LED?) plug for orientation except for
a molded triangle over one of the two holes.
Len Miller
Eradicate threes in my NOSPAM address
about orientation.
Len Miller
