Front panel switches
Dec 29, 2017
43
I started to build my pc and I only have h.d.d led + and - in the same switch thing and power sw and can i use only these or do i need the rest like reset SW and does other ones
If you don't connect Reset Switch, you can't use reset button.
If you don't connect Power or HDD LEDs, those LEDs will not light up.
If you don't connect HD audio cable, you can't use front mini-jacks for headphones/microphone.
If you don't connect USB cables, you can't use front USB ports.
What DO i miss out on Without the other connectors?
Reactions: nikita2004piatrenka
