Front panel to motherboard connectors adapter
harold6811
I need to know where I can get the new style plugs so I can adapt a older enclouser to a new MB. My old system is a Emachine with a flat single plug. Thanks
If you don't already have them, you'll need to buy a set of cables like http://www.directron.com/cbfrpan.html (or similar).
Document the Emachine front panel wiring before cutting the wires. You should properly isolate the solder joints to prevent short circuits with the case or other components.
