S sandrounknow34_ Sep 24, 2018 3 0 10 Sep 25, 2018 #1 Hi guys i have a question, is my case configuration correct for a good air flow ? Thanks https://imgur.com/gallery/ts6GpkX
Solution jojesa Sep 25, 2018 You should turn the rear fan to act as exhaust. That current setting might create turbulence inside the case.
jojesa Glorious Dec 6, 2006 7,193 555 47,440 Sep 25, 2018 Solution #2 You should turn the rear fan to act as exhaust. That current setting might create turbulence inside the case. Upvote 0 Downvote Solution
