Front Rear Audio is not working
juniiflow
590
Is there a reason as to why here are my motherboard and case,
http://pcpartpicker.com/part/thermaltake-case-vm30001w2z
http://pcpartpicker.com/part/asrock-motherboard-h77m
Also if any of you could tell me which cable is the one for "the front rear" to reconnect it, or to check if it's not connected.
Also what does the black audio jack does? is it the same as the green one, to give audio, because no audio it's coming out if i use my headphones with it.
Vic 40
Polypheme
Herald
Oct 22, 2013
14,949
2,313
I guess you mean just the front audio that isn't working?
For the cable question read the manual for your motherboard and connect the right front panel cables to the right pins in the right way.
What the black audio port does at the back i/o is also to be found in the manual for your motherboard,but it is for an audio surround set-up and one of these can be directly connected to the black port in that case.
The motherboard manual is the top download of these,
http://www.asrock.com/mb/Intel/H77M/?cat=Manual
juniiflow
590
Well yeah, just the front panel not the one in the back.
Also whats the name of the cable in the guide i only see one, so does that mean i can have the front panel audio jacks work with this motherboard?
Vic 40
Polypheme
Herald
Oct 22, 2013
14,949
2,313
Was trying to avoid to have to read the manual.:p
Instructions (look at this one between the cables form the case),
If you use AC’97 audio panel, please install it to the front panel audio
header as below:
A. Connect Mic_IN (MIC) to MIC2_L.
B. Connect Audio_R (RIN) to OUT2_R and Audio_L (LIN) to OUT2_L.
C. Connect Ground (GND) to Ground (GND).
At the bottom row the most right one for the Left audiochannel,the third from the right at the bottom (middle one) for the Right audiochannel.These marks should be on the pins i.e. L/R.
Front panel audio is located here=nr. 30,
juniiflow
590
Sorry late, really late reply but I apparently gave you the wrong manual
ftp://66.226.78.21/manual/Z77%20Pro4-M.pdf
Is this one but even tough I search for an asnwer and know the cables that are not connected,
I don't know were to connect them.
If you would't mind using a red highlight to tell me were I should jack in the cables on this picture:
I really haven't found a 9-pin connector on the entire motherboard for the cable below.
Just to make sure, this is the cable I need to connect, right?
Vic 40
Polypheme
Herald
Oct 22, 2013
14,949
2,313
Yes that is the cable and you can connect it to the connector just above the pciex16 slot,just a little bit to the left,Looking at that picture as you put it there.
juniiflow
590
Sorry but in none of those, the HD Audio and AC'97 cables fit.
Look at the holes on this cable
I honestly don't see anywhere where they will fit, I've tried doing it on my own computer but they just don't fit with the pins.
maybe i am wrong, but I've tried every one of them.
Vic 40
Polypheme
Herald
Oct 22, 2013
14,949
2,313
You're looking at the wrong place,it's this one,
could have been found in the manual.
Similar threads
