I think your confused on the whole "DDR" thing. DDR is a way of doubling bandwidth on a clock cycle by sending 2 bits of data instead of one. This is done on the rise and fall of each clock cycle.
So, a 200mhz FSB on a Duron/Athlon is really 100mhz doubled (hence, it is sort of 200mhz). The whole idea is that if you can send two bits in one clock cycle you are really doubling the clock speed.
And yes, the FSB is the speed at which the northbridge and memory operate at. After the northbridge processor is gets slower- AGP is 66mhz, PCI is 33mhz, etc.
Now, don't confuse DDR with the P4's "quad" bus which supposedly runs at 400mhz. Intel decided not to go with DDR and just make 4 pathways for data that all run at 100mhz all going to the memory and northbridge. The problem with this is your not actually getting any speed advantage, rather your getting a bandwidth advantage. I personally think the quad bus design is a little flawed because it's still limited to 1 bit per clock at 100mhz.
-MP Jesse
"Signatures Still Suck"
