Front Side Bus will be Intel's undoing
Who makes your favorite processor?
  • AMD
    Votes: 22 48.9%
  • Intel
    Votes: 19 42.2%
  • VIA
    Votes: 0 0.0%
  • IBM
    Votes: 0 0.0%
  • Other
    Votes: 4 8.9%
  • Total voters
    45
elpresidente2075
851
Intel is once again utilizing a front side bus for its next generation of processors. In fact, the plan is to use the bus to communicate between the two dual cores in their planned double double (quad core) CPU's. Sure, the front side bus is still viable, but it pales in comparison to AMD's direct connection through Hyper-Transport.
This disparity, I predict, will cause exponentially greater differences in performance between the conroe and K8L generation of processors, especially when they both move to quad core and 65nm. I would also like to keep in mind that Conroe is pretty late to the game, Pentium having been spanked viciously by AMD and the Athlon64 for the past few months (years?). Even though it will have the performance crown for a couple months, it will be regained by AMD when they release the K8L series with the on the AM2 socket and with GOOD DDR2. Hopefully by that time the DDR2 timing difficulties will be ironed out, and the Athlon will rise from the ashes, having been beaten to smitherenes for a couple of months, and cause all sorts of havoc for Intel. And yes, I do believe history repeats itself.
Then we will see who owns the crown.
sdrawkcaBgoD
354
Here's a suggestion for your next thread title:
CLICK TO ENTER FLAME WAR!
Note: You absolutely must capitalize the entire sentence.
theaxemaster
375
Just for clarification, HT is AMD's FSB. And no one is really sure whether or not the high end opteron-style core-to-core communication will make it to the 65nm X2's or if it won't be there until the K8L.
blancj
25
But how much is it (braces for the premium price)?
Well theres the rub huh? As far as I am aware you cant buy just the processor, its only available in a workstation/server system
But if the last ball park figure to float through my company was correct a mid range Blade workstation runs the high single K range.
(And I almost typed this on a Blade 2000. Well its in the loop anyway.)
Similar threads
