front usb 3.0 chassis dont work/give power but my mobo 3.0 works
Leslie_33
9
hi,
For some reason my front usb3.0 slots aren't working (from my corsair tower).
My other usb3.0 slots work perfectly fine.
But I need the front for my headset and external hard drives.
I cant get them to work.
Any solutions?
Since the usb3 back ports are working, drivers for it are installed.
Check the usb3 connection to the motherboard. It is the plug next to the dimm slots under the 24pin atx power;
Hi,
Your other usb3 ports i assume are at the back?
Have they worked before? Have you done any work inside the case since? Check the usb3 header from the case is connected to the motherboard usb3 pins and are on properly.
What motherboard do you have?
yes my other usb3 are at the back they work. the front usb3 have worked recently. I have re-installed windows yesterday and they didnt work since. I've only detached and re-attached my HDD.
I have msi z97s sli krait edition mobo
Thanks must have accidently bumped my hand to it and it disconnected :l
Everything works fine now thank!
