FS: LV6100 -- WG6100 low voltage PS
G
Guest
Guest
Archived from groups: rec.games.video.arcade.collecting (More info?)
I finally got some time to rebuild a couple of my 6100s, so I build up
a hand ful of LV6100 -- WG6100 replacement low-voltage power supply boards.
Just strip off all the components in the 100's (other than the degaussing
circuit), solder in 5 wires, and you're done.
$30 each, or 4/$100
Mark Spaeth mspaeth@mtl.mit.edu
50 Vassar St., #38.265 mspaeth@mit.edu
Cambridge, MA 02139
(617) 452-2354 http://rgvac.978.org/~mspaeth
G
Guest
Guest
Mark C. Spaeth <mspaeth@plancherel.mit.edu> wrote:
: I finally got some time to rebuild a couple of my 6100s, so I build up
: a hand ful of LV6100 -- WG6100 replacement low-voltage power supply boards.
: Just strip off all the components in the 100's (other than the degaussing
: circuit), solder in 5 wires, and you're done.
: $30 each, or 4/$100
Sold out...
I'll post again when I run more boards...
Cambridge, MA 02139
Thread starter Similar threads Forum Replies Date
S PC Gaming 0
B PC Gaming 3
R PC Gaming 4
Similar threads
