So historically, my overclock had been done exclusively on multiplier. Using the multiplier, I could keep my CPU stable at 4.6Ghz in the summer (I did have it at 4.8Ghz in the winter, but it can't shed heat fast enough. I was reading the very thorough "Overclocking the AMD Bulldozer" guide, which said that overclocking the FSB is superior to overclocking using the multiplier. I was trying to follow the directions, the only problem being, I can't get anywhere near where I was before (I can't get it to even hold a 4.2Ghz clock, which is the stock clock). I'm an absolute rookie at this, so I'm sure I've done something wrong. I also tried adjusting the DRAM to get it near 2133Mhz (Which is what it was before I played with the clocks), and tried to keep northbridge and HT links equal at around 2500Mhz.
I know the thread says to just keep adjusting until it crashes, then back off, the only problem being my board makes it very difficult to reset each time (I have to take out my videocards, remove the BIOS battery, wait, then start over).
My specs are:
MB: MSI Gaming 970.
CPU: AMD FX4170 Black Edition (Waiting for the new generation of AMD CPUs).
PSU: Antec 850W.
RAM: 4x4Gb of G.Skill Trident 2400Mhz C10.
Video Cards: A pair of XFX R9 280X, Crossfired.
Cooler: NZXT Kraken x61 (With a push-pull setup).
Case: Zalman Z11+ (Five intake fans, five exhaust fans).
Any help, advice or solutions to what I've done wrong would be massively appreciated.
My specs are:
MB: MSI Gaming 970.
PSU: Antec 850W.
