Hello I have a problem with the above fujitsu motherboard, i bought it, installed it in a pc case, connected everything when I saw that the power button connector didn't fit but the motherboard would power on when was plugged in to the outlet, and monitor would display no signal no matter if connected through the vga port or a graphic card. I ordered a power switch with the connectors needed, left the Pc in a secure spot for a few days now I tried to switch it on ( before connecting the new power button connector) but it won't turn on, I unplugged everything one by one from the motherboard and nothing, I tried a different power lead and different power supply, still nothing, So I dont know what may be causing the issue I would really appreciate if someone has an Idea as of what may be causing the problem, the motherboard just seems to not be getting any power to it at all.
