Hi all
I haven't seen this directly talked about, only in one thread did it seem my assumption could be wrong--- which was good to read and get educated on.
I've posted about a new build and in that build I'll have two SSDs, two older SATA, and possibly a third SATA and so for that was assuming I would buy a Full tower... but I was thinking, and I think I'm wrong based on the last few minutes' reading, that a larger case allows for drives not to be stacked right next to each other, allowing any front fans to do a bit more, air circulates more around the drives (current case is an Antec 1200 with 3 front fans and I spaced the drives out as I could).
But I saw it suggested that sometimes that extra space can lead to circulating issues, more than improving air flow around drives etc. Also, that a side fan, even if blowing right at your gpu, may not be doing so much for it.
-- is this a line of thinking worth taking into consideration? I think my number of drives means that I'm buying a Full tower, but is a Mid, if it's got the bays, be acceptable or hell, preferable? I get Phanteks Enthoo Pro Mid recommendations like crazy, but only one fan?!?! right, water cooling, I get it, not for me though.
Drive numbers (in my case, 4 or 5) has a bit to do with this yeah, but outside of that, I'll only have a single gpu and only air cooling...
Thanks.
5820K
Asus 99A
32G RAM
980Ti
no idea as to case
thermaltake toughpower 850 Gold
Thanks.
5820K
Asus 99A
32G RAM
980Ti
no idea as to case
