Build Advice Future Proof Upgrade Advice Needed. Triple Monitor Business Machine
Keystone4132
40
I would like the community’s opinion on which if any components I should replace/upgrade so that my system is fast, reliable and future proof for at least the next 3 years. Thanks for reading my post.
Approximate Purchase Date: Black Friday/Cyber Monday
Budget Range: Unlimited. Money is not an issue if there is a clear benefit to replacing/adding a component.
System Usage from Most to Least Important: I am an investor and spend my days evaluating investments.
  • Fast Windows startup
  • Reliability
  • Programs open quickly. Performance is not impacted by multi-tasking.
  • Browsing: not unusual to have 10-50 tabs open across 3 monitors.
  • ‘Think or Swim’ stock trading app open all day. (TDAmeritrade)
  • Photography: Lightroom/Photoshop (Adobe Creative Cloud)
  • Excel spreadsheets with extensive financial models
  • Quicken: 200MB file. Large database can be slow.
  • Email/Word processing
Are you buying a monitor: Not planning to upgrade monitors.
Parts to Upgrade: This is the reason for my post. I am open to upgrading any or all of my system. See www.pcpartpicker.com link below for the current system configuration.
Do you need to buy OS: Yes. Currently have Windows 7, which is going off support.
Preferred Website(s) for Parts: www.pcpartpicker.com
Parts Preferences: No
Overclocking: No
SLI or Crossfire: No. I have a triple monitor setup now, but each monitor is a separate window
Your Monitor Resolution: 1920x1200
Additional Comments: I am not a gamer. I do not stream video. I do use Microsoft Office, Think or Swim trading software, Lightroom/Photoshop, and Quicken. Chrome is my default browser.
And Most Importantly, Why Are You Upgrading: I would like the community’s opinion on which if any components I should replace/upgrade so that my system is fast (for above uses), reliable and future proof for at least the next 3 years.
I evaluate my system every 3-4 years and buy parts as needed over Black Friday/Cyber Mondays. I purchased components in 2011, 2013, and 2016. I want my system to be up to date and reliable for the next 3 years. I will be upgrading to Windows 10.
Issues I’d like to address:
32G DDR3. Am I getting the full benefit?
Hang/Slowing. My machine can hang if I have multiple programs open: Think or Swim open along with Excel and numerous browser tabs.
Black Screen. I occasionally get intermittent black screen or screens, that last for 5-10 seconds (especially after Windows Updates).
Lightroom. When I am in Lightroom processing photos, I minimize the number of other programs I have open because it can slow things down.
Aging Storage. I have some older SSD/HDDs. I am open to replacing them.
Dates Purchased
2011: PSU, CPU Cooler, SSD 128G, HDD 1TB, Case, Optical Drive
2013: NAS, (2) HDD 4TB
2016: CPU, MoBo, GPU, Monitors/DPCables, SSD 850G, HDD 3TB, Win7
Current System Configurations:
https://pcpartpicker.com/list/vFVwzN
CPUIntel Core i7-4790K 4.0GHz LGA 1150 Quad-Core ProcessorBX80646I74790K2/5/2016
CPU CoolerCOOLER MASTER Hyper 212 PlusRR-B10-212P-G17/22/2011
MoBoAsus Z97-A/usb 3.1 LGA 1150 ATXZ97-A/USB 3.12/5/2016
Memory - DDR3Corsair (8Gx4=32G Total)CMZ32GX3M4X1866C103/28/2017
SSD DriveSamsung SSD 850 PRO 512GBMZ-7KE512BW1/17/2016
SSD DriveCrucial M4 128 GB 2.5" Solid State DriveCT128M4SSD27/22/2011
HDDWestern Digital BLACK SERIES 3 TB 3.5" 7200RPM Internal Hard DriveWD3003FZEX1/17/2016
HDDSamsung Spinpoint F3 1 TB 3.5" 7200RPM Internal Hard DriveHD103SJ7/22/2011
GPUSapphire Nitro R9 380 4G GDDR5 PCI-EModel Number: 11242-13-20G2/8/2016
CaseLian Li PC-Z60B ATX Mid Tower CasePC-Z60B7/22/2011
USB Card ReaderAtech PRO-77U USB 3.0 Card ReaderPRO-77U1/22/2016
PSUCorsair Professional 650 W 80+ Gold Certified Semi-modular ATX Power SupplyCMPSU-650HX7/22/2011
Optical DriveAsus DRW-24B1ST/BLK/B/AS DVD/CD WriterDRW-24B1ST/BLK/B/AS7/22/2011
OSWindows 7 Home Premium SP1 OEM 64-bit2/5/2016
MonitorDell U2415 24.1" 1920x1200 60 Hz MonitorU24151/30/2016
DisplayPort Cables(2) Accell DP to DP 1.2 - VESA-Certified DisplayPort 1.2 Cable - 10 Feet, HBR2, 4K UHD @60Hz, 1920x1080@240HzB142C-010B2/14/2016
DisplayPort Cables(2) Accell DP to DP 1.2 - VESA-Certified DisplayPort 1.2 Cable - 3 Feet, HBR2, 4K UHD @60Hz, 1920x1080@240HzB142C-003B2/14/2016
KeyboardLogitech K780 Wireless Slim KeyboardK780
MouseLogitech G900 CHAOS SPECTRUM Wireless Optical MouseG9002/7/2017
NASSynology DiskStation 2-Bay (Diskless) Network Attached Storage DS213+DS213+8/22/2013
HDDSeagate SATA 6Gb/s 3.5-Inch 4TB Desktop HDD (for NAS)ST4000DM0008/22/2013
Thanks for your reply.
My system works fine with the exception of the items I mentioned. The goal is to make updates that will keep it running at top performance for the next 3 years. I have to upgrade to Win10 as MSFT will stop supporting Win 7 shortly, and want to take care of any hardware changes while I was working on my system. I have an 8-year-old PSU and some aging HDD/SSDs. I want to be proactive in maintenance/upgrades rather than have the system fail at an inconvenient time (which is always the case).
I hear you on the state of hardware.
Welp, You may have to get a new setup altogether...
the problem of black screen is gpu. get gtx 1080
cpu upgrades get a 7700k
get ddr4 2133mhz ram up to 64gb
get a mobo that supports all that
if you are upgrading hard drive, you could get a Seagate Constellaiton es.2 sed ST33000651NS hdd (its 3tb) get 3 of em
