Hey folks,
Just seeking some advise even though I might not even be able to explain it properly as I dont even know how to explain it, so I've attached a video of the issue, but due to the quality of it I bet you wouldn't even be able to tell, but either way I got this monitor a week ago: "ASUS TUF Gaming VG259QM 24.5” Monitor, 1080P Full HD (1920 x 1080), Fast IPS, 280Hz , G-SYNC Compatible, Extreme Low Motion Blur Sync, 1ms, DisplayHDR™ 400, Eye Care, DisplayPort HDMI" with I7 9700K - RTX 2070 - and worked like a charm for a week, but suddenly this morning either before or after windows update, dont know, possibly unrelated, something happened color vise.
When I dont touch anything with my mouse cursor on screen its all perfectly fine, but when you move an object, such as in the video, or in game, you can see some sort of ripples or contrast issue, fuzziness? I openned a few games and when I stare at the wall standing in front of it picture's clear, but as soon as i move left/right while staring at the wall it kind of changes its color, or not the color, but its sharpness, it has some sort of a fuzzy acid effect as if you are purposely applying some sort of a video effect while creating a movie or something, i cant even explain it properly, sorry, cant think of the right words, wanted to give an ingame example, but afraid due to quality it'd be awful, so ya, if anyone has at least an idea what i might be talking about that'd be awesome! It's like literally picture is fine, colors and all is fine, its literally you perform an action and it all kind of blurs or not sure, yet my monitor's settings are set correctly, i have no blur, not using any specific filters, so ya, dont know, but its really disturbing to the eyes.
I've reseated display cable, restarted, changed from 280hz to 144hz and no change, disabled gsynch to try without, no change, doesnt seem to be a gamma management issue where i did try to lower brightness a bit the other day, but that didnt cause any issues, i deleted both display color management profiles, tried downloading an ISP color callibration profile to see if that helps specifically for this monitor, but no change. Issue is somewhere else.
Could it be the new display port cord that came with the monitor or the screen itself that i should return?
Thanks
If you're gonna be viewing the video try to concentrate on the actual words at the top where you see "Pin To" etc, stare at one thing, and see if you can feel exactly what I mean by looking at a clear as day looking words, then as you move the thing, the color drops and kind of fuzzes or becomes kind of acidy?
Below is an example I just made up on purpose via windows movie maker, this is NOT what I see, i just randomly added a couple of effects of how the color changes in game from normal to that acidy one, but its not as bad as on my example, in game or in windows its not really changing to what you see on the below screenshots, but its still disturbing enoguh for the eyes to notice.
NORMAL
NOT NORMAL
NOT NORMAL
Once again its not really whats happenning, but approximetely thats what i mean when i say picture changes to something fuzzy or bright with acid ripples or what not for just mini seconds as you move away from staring at an object in game, while moving its happenning, when staying still its not.
any ideas are appreciated
Thanks
NORMAL
NOT NORMAL
NOT NORMAL
