Fx 4300 and ASrock 970M Pro3
aaronmcg123
72
Hi there im getting offered a swap for my i5 2400s for an AMD Fx 4300 and an ASrock 970M Pro3 motherboard, should i take the swap ill be doing editing and gaming on the system, is it worth it ?
But if i were to take this and say upgrade the cpu to an 8350 or something similar would i be better off doing that rather than buying a brand new lga 1150 board and a cpu to match as that would be my other option as i want to go 1150 rather than stick with the 1155, i am in no way disagreeing with the advice you have given me just would like to know what my best option is as im on a tight enough budget
Okay thanks for the advice man helps alot, ill save up now and get an 1150 board and a solid i5
