fx 4300 pc build check and memory help
xray 11
hi I am buildind a pc I need help as to know if this pc build valid or not-
1.amd fx-4300http://
2.gigabyte 78lmt-s2pvhttp://
3.450 w corsair vs psu http://
4.asus dvd writer
5.r7 250 1gb ddr5 graphic card
also I need help with the ram which could be supported need 4gb(1333mhz) ram I will be buying this from-
http://
plz reply asap thanks for the help in advance
I live in India I gave the link to the site I buy
http://www.snapdeal.com/
just want to know if this config will work or not also suggest me a 1333 MHz ram from this site plz reply asap
