Does the FX 4350 require fewer volts to reach 5.5 GHz compared to the FX 8350 or FX 8370/9590?
I am planning to overclock the 4 core 4350 (no need to say it sucks, this is what i have sadly) to 5.5 GHz on my CM Nepton 280L in 4 fan push pull configuration.
Right now at 1.48750v LLC Medium@4.70 GHz I am running at 50°C Intel Burn Test stable 2 hours.
I have tried 1.50000v LLC High but it only reaches 4.80 GHz stable IBT 2h. Are there other settings other than VCore to increase for higher clocks?
Are the temperatures too high for my current voltage and cooler?
Is this chip a dud in overclocking? (taking too much voltage?)
Is 1.55000v LLC High/Extreme safe for the chip? What temperatures or voltages are safe?
Thank you in advance.
