FX 6100 Temps
Warren Amalsad
7
I was wondering what is the safest temperature the FX 6100 CPU should reach. I've been running Prime95 for a while now and it seems to stay at 52 degrees constantly. I'm running a pre filled liquid cooler btw.
depends some say 2-4 hours some say 24, I personally think (based on what I saw myself) after 2 hours there wont be any difference in max temp then 24. But if you do some overclocking I recommend to do it atleast 8 hours for stability testing.
ya i think since my temps are pree low ill be over clocking it soon. by the way are there any free programs that i can use the stress test my GPU.
