so i am getting an AMD fx 6300 processor some time soon, and i need a motherboard.
I live in the UK so i need to be able to buy it off amazon or what have you.
I have heard that a BIOS update is needed to run this CPU on most motherboards and i really dont want to have to do this.
So could someone suggest a motherboard that will support AMD fx6300 with no BIOS update and cost less than £50
I was originally looking at the:
thanks in advance
but i dont know if i need a bios update, if you cant suggest a motherboard please tell me if this one needs an update or give a good tutorialGigabyte GA-78LMT-USB3 Micro ATX AM3+
thanks in advance
