Hello there, i just have bought a cooler master hyper t4 for my FX 8120, i've been testing some temps and stability with Prime95.
Thing is i got my CPU to 4,0Ghz using only multiplier at x20 with a manual voltage of 1.25 (which might be a little bit low, but i don't get any BSOD for now)
But then when I run Prime95 and check temps and overlock with Cpu Temp it shows me that most cores works only to a 2,8Ghz while others jump to 4,0Ghz and then low again to that 2,8Ghz.
I have tested before with the same programs and less voltage at 3,5Ghz and all cores stayed at that amount over time.
Is this normal? what can I do?
Currently I believe I have C1E and Cool & Quien on in the Bios setting. No turbo or anything. My mobo is a M5A99X EVO
Edit1: Tried with prime95 again and I got a system restart, gonna try with some more voltage.
Edit2: Sorry C1E is disabled in BIOS and C6 is enabled.
