Hi,
I have a fx-8320 paired with a gigabyte 990fxa-ud3 MB that I purchased from Microcenter recently. I see a strange situation in which I am running Prime95 with the CPU being overclocked to 4.4 GHz on a +0.050 Vcore voltage increase. I have turned turbo mode off and C(c&q) off as well. The Vcore is jumping between 1.368 and 1.5V. While there are no BSODs or hanging situations, I see that the core speed is bobbing up and down from 2913 MHz on the low end to 4420 MHz on the high end. I also see that it seems to do that when the temps go beyond 43c. Below 43c, it seems to stay at 4420 MHz without downspeeding to 2913 MHz. Am I providing enough Vcore for the CPU to function or is it downspeeding because of the temps?
I am using a CM Hyper 212 plus air cooler. Seems not a whole lot warm to the touch although the VRM heat sinks seems to be a tad hot. Any help is appreciated. Thanks
tommy
tommy
