Hey, Will 500watt be enough for running a gtx 650 ti and a FX-8350? :)
K konne Honorable Mar 28, 2013 1 0 10,510 Mar 28, 2013 #1 Hey, Will 500watt be enough for running a gtx 650 ti and a FX-8350?
biopolar Honorable Mar 7, 2013 157 0 10,710 Mar 28, 2013 #2 Depending on the brand of the PSU, if you're going generic, then no. 8350 is a power hungry cpu and demands power. What was the PSU you were planning on buying?
T twelve25 Distinguished Oct 8, 2012 1,976 0 19,960 Mar 28, 2013 #3 Yes, even if crappy PSU. 8350 uses 125W and the 650 Ti less than 100W.
8350rocks Distinguished Mar 14, 2013 6,235 0 18,460 Mar 28, 2013 #4 twelve25 : Yes, even if crappy PSU. 8350 uses 125W and the 650 Ti less than 100W. As long as he doesn't SLI 2 or more cards he should be fine
S skurtov Honorable Sep 21, 2012 56 0 10,640 Mar 28, 2013 #5 Errr. I'd get a higher wattage psu. With his setup he's going to eventually want more power, or even an upgrade. It would be better buying one psu rather than one now and another later
