Fx 8350 build Need Help Merry XMAS
CPU: AMD FX-8350 4.0GHz 8-Core Processor ($189.99 @ Amazon)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($29.98 @ Amazon)
Motherboard: Gigabyte GA-990FXA-UD5 ATX AM3+ Motherboard ($149.98 @ Newegg)
Memory: Crucial Ballistix 8GB (2 x 4GB) DDR3-1866 Memory ($42.99 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($76.99 @ Amazon)
Video Card: Sapphire Radeon HD 7950 3GB Video Card ($289.99 @ Newegg)
Case: NZXT Source 210 (White) ATX Mid Tower Case ($35.98 @ Newegg)
Power Supply: Corsair Builder 750W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply ($64.99 @ Newegg)
Optical Drive: Sony AD-7280S-0B DVD/CD Writer ($18.99 @ Newegg)
Total: $899.88
(Generated by PCPartPicker 2012-12-26 02:15 EST-0500)
this will leave room for optional
OS
SSD
8350 and Gigabyte GA-990FXA-UD5 is beast for overclocking
sapphire 7950 has the higher clock around, you might want to consider 7970 for 350
just my 0.02 someone can improve this build
Thats nice all i will change is the case hdd and the hardrive is the builder series reliable as the nthusiast series?
This is pretty much the best you can build for that price.
CPU: AMD FX-8320 3.5GHz 8-Core Processor ($151.08 @ Amazon)
Memory: Mushkin Blackline 8GB (2 x 4GB) DDR3-1600 Memory ($39.99 @ Newegg)
Storage: Western Digital Caviar Black 1TB 3.5" 7200RPM Internal Hard Drive ($89.99 @ Amazon)
Video Card: Sapphire Radeon HD 7970 3GB Video Card ($366.97 @ Newegg)
Case: Antec P280 ATX Mid Tower Case ($79.99 @ NCIX US)
Power Supply: XFX ProSeries 750W 80 PLUS Silver Certified ATX12V / EPS12V Power Supply ($79.99 @ NCIX US)
Operating System: Microsoft Windows 8 (OEM) (64-bit) ($89.98 @ Outlet PC)
Total: $1104.96
(Generated by PCPartPicker 2012-12-26 04:59 EST-0500)
Note that i did not include a CPU cooler because since the FX 8320 and FX 8350 are the same chips, you can overclock the FX 8320 to 4GHZ easily using the stock cooler.
I wouldn't recommend the gigabyte if your into overclocking
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131877
its a $10 difference if you don't use the mail-in rebate (or if they don't give it to you). $5 is in the shipping for gigabyte.
My experience: gigabyte is simple user friendly, max oc on my chip was 4.4 ghz
Asus was a bit more complex in the bios but infinitely more options. same chip, 4.7 ghz.
also do not get windows 8. its designed for touch screens.
