after several tries of getting bsod without passing test 1 in prime 95.
i tried this one.
i changed the asus profile to extreme.and disabled amd turbo core.
and manually changed the cpu ratio(4.4 ghz).
and disabling cpu and pci spread spectrum.
and manually setted cpu voltage to 1.45v. and it passed 3 tests . results below..
http://s1352.photobucket.com/user/praveen1996/story/98045
but the cpu temp was max at 73c. i use hw monitor to see temps . im confused about which cpu temp to notice .
in motherboard it shows 73c(max) while at amd fx8350 temps show 53c(max).answer this..
i stopped the test because of max temps. is this a stable overclock!!!!!!!!!!!
and another question im using corsair vs 550(550w) psu with amd fx 8350,2gb hd 7850,8gb ram,
could this damage my psu............
i tried this one.
