J Juggalo66 Honorable Jan 5, 2014 9 0 10,510 Jan 13, 2014 #1 I was just wondering while playing dishonored my cpu is 41 degrees centigrade is that OK or is it to hot I have an h100i liquid cooler
Solution fjaesbog Jan 13, 2014 41 degress celsius is perfectly fine. The temps shouldn't exceed 60. Below 60c it's safe.
fjaesbog Honorable Aug 6, 2013 729 0 11,360 Jan 13, 2014 Solution #2 41 degress celsius is perfectly fine. The temps shouldn't exceed 60. Below 60c it's safe. Upvote 0 Downvote Solution
J Juggalo66 Honorable Jan 5, 2014 9 0 10,510 Jan 16, 2014 #3 thank you very much srry for the delayed response internet got cut for a bit Upvote 0 Downvote
J Juggalo66 Honorable Jan 5, 2014 9 0 10,510 Jan 16, 2014 #4 after 30mins on prime95 it only hits 48C the temps lowered because i tightened the h100i cooler it was a bit loose. i was worried when i installed the h100i that i tightened the heat sink to tight. my buddy did that and broke some pins on his cpu Upvote 0 Downvote
