Hi all , i'd really need some help. I have this fx-9590 and i would like to keep it cool for long times because it shuts down around 79C while playing high end games ( far cry 4 , ac unity, and so on).
Now i'm using arctic freezer a30 by the way, but a30 can't handle this cpu it seems.
my rig:
CPU: AMD FX 9590 8x4.7GHz (arctic freezer a30 atm )
RAM: 2x4GB DDR3 1600 Corsais Vengeance CL8
GPU: Gigabyte Radeon R9 290 Reference 4GB 512bit gpu
MB: ASUS SABERTOOTH 990FX R2.0 MB
256GB Hynix SSD
PSU: Chiftec 750W modular psu
HOUSE: Zalman Z11 Plus with +1 fan ( 12 cm)
I was looking at the zalman reserator 3 max dual or the zalman reserator 3 max water cooling system. It says it fits in my pc house ( i'm not sure though). zalman claims this cooler can handle heat up to 400W.
Will it keep the fx 9590 under 60C for long time under stress( games) ??
Will it fit for my rig? which one to choose dual or simple?
Thanks in advance for any helpfull replies.
my rig:
256GB Hynix SSD
