My current system
-Windows 7 Pro x64 on a 500GB SSD
-x5 HDD totaling 6TB together
Case: Raidmax Agusta
MB: ASUS Sabertooth 990fx R2.0
GPU: 2GB GTX 760
RAM: 16GB DDR3
CPU: 3.5GHz AMD FX 6300 w/ Cooler Master GeminII S524
PSU: 750W
First off, I want to state: I AM NOT AN OVERCLOCKER. I WILL NEVER OVERCLOCK MY PARTS.
Anyway, I want to upgrade my current AMD system as much as I possibly can without buying a new motherboard. I intend to upgrade to 32GB of DDR3 RAM (I am not concerned about the MHz speed at all regarding memory) & a GTX 980 ti.
The CPU that looks best to me is the FX 9590. It's stock speed is very catching to me plus it's compatible with my motherboard. I understand it's a power hungry thing and I will upgrade my PSU to 1000+W alongside it.
My concern is cooling. I know this thing requires liquid cooling, no ifs, ands or buts. But I'm unsure of my options. I haven't done water cooling and I'm finding conflicting results for both coolers good enough for 9590 as well as coolers that will fit my case.
I was wondering if a 120mm radiator would do?; I know I could mount it at the back of case on the outside, with a fan inside the case blowing air over the radiator & out of the case and one outside on the other side of the radiator, blowing away from the case (push/pull I believe is the term). If that would work, what 120mm sized liquid cooler would be best to keep the 9590 cool? (I render videos alot, however, my 6300 only reaches 80% usage & 31C temps when I set my program to use both CPU & GPU for rendering)
If one that size is out of the question, I'd probably need a new case- which is fine as I was intending to move this build to a new case anyway once Windows 7 support ends in 2020 and make it an offline system because 10 has absolutely not worked at all with my editing programs and I despise Microsoft's shady practices regarding that OS.
If it comes to that (new case), what case would fit a large radiator as well as my motherboard, a GTX 980 ti, a 5.25" Bluray Drive 5 3.5" HDDs and one 2.5" SSD?
And what liquid cooler would be the best for the 9590 at stock & full load?
Money's not too much of an issue, but I would like to keep it under $200 for a liquid cooler and $150 for a case if possible. Again, not too big of an issue, just a preference.
On a final note, noise is not an issue as I'm a heavy headphone user.
GPU: 2GB GTX 760
RAM: 16GB DDR3
PSU: 750W
