i just got done throwing together my new rig its as follows
FX 9590
Asus Crosshair V Formula Z
16GB 2400 ddr3 Gskill
Cooler Master 120m Saidon
WD Black 1TB
(thermal compound Arctic Silver 5 )
im just trying to figure out the max safe temp for the 9590 so that i can set up my temp program so that it shows warning before gets hot enough to damage my CPU or anything else only got the 120mm fan the cooler came with on but idle running 15c and under strain running ARK survival evolved for 3 hours hit max temp of 56c just trying to figure out what max temp is so can set up a safty shut off / sleep mode so dont get to hot and overheat or anything definetly going to be getting 2 aftermarket 120mm fans to put in a push pull config on the radiator but for now i just would rather be safe than sorry so was hopping for a bit of feed back on max safe temp hope to get some replys
FX 9590
WD Black 1TB
