Did you clean the cpu heatsink of fluff when you reseated it??.
I would go further than lewis, I suggest you check ALL the settings in BIOS, especially multiplier setting/cpu speed; and perhaps reset them all to default if you are concerned about any of them.
The cpu temperature shown is the average of all cores, actual core temps can be a fair bit higher, I would be worried that the cpu has fried; AMD cpus dont really work well about 55C, so 80+ may well have damaged it.
If all the settings seem ok, you reset the BIOS, and are still having issues, you may have malware/a coin miner. Get hold of some stand-alone AM and AV programs on a USB stick and boot into Safe Mode to run them.
I downloaded an update of a trusted program that had been hacked to include a miner; my cpu went straight to 100% all cores and temps started shooting up; luckily for me, my water cooling system was enough to stop it reaching critical levels, so I could identify and stop it.
(I stress tested the water cooler with 100% all cores to set the max over-clock months before).
