FX8350 water cooling
The H60 is very iffy to use, it is usable but you'll be getting higher temps under load and I would not recommend overclocking on it. I would really suggest going for something bigger such as the H90 (http://www.newegg.com/Product/Product.aspx?Item=N82E16835181036) and if your just looking for a budget build with great cooling for the price look into getting a hyper 212. I've been using it on my 8350 for as long as I can remember and trust me I push it to its limits and it hasn't failed on me yet!
