Hello i cant run my rams on 3600mhz no post
I enable the docp to 3200 mhz and no problem why m/b problem ram problen or something else????
I use asus b550 e gaming any way to run in 3600mhz safe?
Amd 5600x officially supports up to 3200MHz so no guarantee an SPD profile for easy Overclocking will work.
You will have to Overclock manually in Bios to get to the rated frequency. Set your Timings to 16-19-19-39 with 1.35V and at 3600MHz and if that don't work try 1.40V dram voltage.
If again unsuccessful then change command rate from 1 to 2.
