G.Skill Ripjaws V 8GB DDR4 2400MHz running at 2133MHz (?)
lephleg
I've purchased a set of G.Skill Ripjaws V 8GB DDR4 Non ECC CL15 2400MHz (F4-2400C15D-8GVR).
After I've installed them at slots 2 and 4 of my ASUS Z170 PRO GAMING motherboard, they are both appearing to be running at 2133MHz (according to CPU-Z).
http://imgur.com/a/v3Fqf
Why is this? Have I configured something wrong? Shouldn't it be 2400MHz?
Thanks!
EDIT: Sorry for posting this in a wrong category.. >.<
I have the same exact ones. You have to go into the BIOS manually change it to 2400. Honestly, though, if it isn't bothering you, and every thing is snappy, you should be fine. If you are unaware of overclocking, I would look at some guides on Tom's Hardware, and read up on it.
