[SOLVED] G.SKILL Ripjaws V Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 not running at 3200
debgram
78
G.SKILL Ripjaws V Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 (PC4 25600) Intel XMP 2.0 Desktop Memory Model F4-3200C14D-16GVK
I checked the X.M.P. but when I put in the DRAM Frequency to 3200 the pc won't boot. I set it on Auto and it boots. But it isn't running at full speed
https://ibb.co/qC9Txkf
Intel i5 8600
16GM RAM
ROG Strix B360-F gaming
Where would I find that info I looked in my manual and I couldn't find it. So I know better on the next MB.
4 x DIMM, Max. 64GB, DDR4 2666/2400/2133 MHz Non-ECC, Un-buffered Memory
Dual Channel Memory Architecture
Supports Intel® Extreme Memory Profile (XMP)
  • Hyper DIMM support is subject to the physical characteristics of individual CPUs.
  • Refer to www.asus.com for the Memory QVL (Qualified Vendors Lists).
** DDR4 2666MHz and higher memory modules will run at max. 2666MHz on Intel® 8th Gen. 6-core or higher processors.
Intel i5 8600
16GM RAM
The max speed for that motherboard is 2666.
so does that mean I would need a different CPU too? thanks
