G Skill Sniper 1600 low voltage ram
Chirality
89
I'm trying to figure out what is happening with a new PC I've made. I can play skyrim for a long while and I have no crashes, then once in a while the game crashes or I blue screen. I tried to play the TOR beta over the weekend and it crashed to the desktop about 10 times before I was able to play it for 5 to 6 hours and take a break. I messed with the settings but I don't understand why my games aren't working right. I also tried to play BF3 but that just didn't work for more than 5 minutes at a time. I know that BF3 is a crap game loaded with bugs so I figured Skyrim would be the game that I could test my system on. It works great 90% of the time.
I've run WhoCrashed and this is what I've been getting over the last few crashes:
On Thu 11/17/2011 8:35:27 PM GMT your computer crashed
crash dump file: C:\Windows\Minidump\111711-10795-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x7CC40)
Bugcheck code: 0x50 (0xFFFFFB00C060A398, 0x0, 0xFFFFF96000109773, 0x7)
Error: PAGE_FAULT_IN_NONPAGED_AREA
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that invalid system memory has been referenced.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver which cannot be identified at this time.
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: win32k.sys (win32k!W32pArgumentTable+0x34957)
file path: C:\Windows\system32\win32k.sys
description: Multi-User Win32 Driver
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system which cannot be identified at this time.
On Tue 11/15/2011 8:25:28 PM GMT your computer crashed
crash dump file: C:\Windows\Minidump\111511-8346-01.dmp
This was probably caused by the following module: nvlddmkm.sys (nvlddmkm+0x251588)
Bugcheck code: 0x50 (0xFFFFFAA003A10970, 0x1, 0xFFFFF88002E31CA1, 0x5)
file path: C:\Windows\system32\drivers\nvlddmkm.sys
product: NVIDIA Windows Kernel Mode Driver, Version 285.79
company: NVIDIA Corporation
description: NVIDIA Windows Kernel Mode Driver, Version 285.79
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: nvlddmkm.sys (NVIDIA Windows Kernel Mode Driver, Version 285.79 , NVIDIA Corporation).
Google query: nvlddmkm.sys NVIDIA Corporation PAGE_FAULT_IN_NONPAGED_AREA
On Mon 11/14/2011 4:21:29 AM GMT your computer crashed
crash dump file: C:\Windows\Minidump\111311-10420-01.dmp
This was probably caused by the following module: rtkvhd64.sys (RTKVHD64+0x53240)
Bugcheck code: 0xD3 (0xFFFFF88006948240, 0x0, 0x1, 0xFFFFF800034EE5F7)
Error: DRIVER_PORTION_MUST_BE_NONPAGED
Bug check description: This indicates that the system attempted to access pageable memory at a process IRQL that was too high.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: rtkvhd64.sys .
Google query: rtkvhd64.sys DRIVER_PORTION_MUST_BE_NONPAGED
On Sun 11/13/2011 6:44:44 AM GMT your computer crashed
crash dump file: C:\Windows\Minidump\111311-12136-01.dmp
Bugcheck code: 0x3B (0xC0000005, 0xFFFFF800034D58E2, 0xFFFFF8800C72FE50, 0x0)
Error: SYSTEM_SERVICE_EXCEPTION
Bug check description: This indicates that an exception happened while executing a routine that transitions from non-privileged code to privileged code.
On Sat 11/12/2011 7:26:20 PM GMT your computer crashed
crash dump file: C:\Windows\Minidump\111211-10810-01.dmp
Bugcheck code: 0xE3 (0xFFFFF900C00BF010, 0xFFFFFA80090C8840, 0x0, 0x2)
Error: RESOURCE_NOT_OWNED
Bug check description: This indicates that a thread tried to release a resource it did not own.
In the beginning I had the CPU overclocked to 4.4, but I couldn't get anything to work and I got the errors that related to the OC. I dropped the OC to 4.2 and I haven't had errors with crashing because of it since then.
Here is my rig.
HD:
WD Caviar Black 1 TB 7200 RPM 64mb cache
Crucical M4 128gig SSD
CPU:
i5-2500K
Mobo:
ASROCK P67 Extreme4 Gen3
GPU:
MSI 570GTX Twin Frozr III PE/OC x 2
Cooling:
Noctua DH-14
RAM:
G.Skill Sniper Low Voltage Series 8GIG 1600
Optical Drive:
LITE-ON 24x DVD Combo Drive
PSU:
Corsair Pro Series 80+Gold 1200W
Case:
Silverstone TJ07
My drivers are up to date as far as I can tell. I've ran Furmark for over 10 minutes and I get a decent 70 C on the primary card so I know heat isn't the problem.
MY OS is Windows 7 64 bit Pro Ed.
I'm not sure what is going on, I can put the factory OC back down to stock settings and I have - but I haven't tested it yet.
What's going on or what can I run/give you guys as far as information goes to help me fix this issue.
Slight update - My ram was overclocked to 1866 Mhz, I know from reading reviews that RAM has a lot of stability issues at higher clocks. I just put it down back to 1600.
Was that my problem????
Insight please!!
Right now I got the OC for the CPU at 4.2 and it's running nice under 1.5 volts - like 1.29 ish last I checked.
The ram at 1600 is around 1.25 and 1.26 volts.
Any other tricks for stability? Also - I'd really appreciate some more insight from everyone here.
