G.Skill Sniper 2133MHz to 2400MHz
Jan 23, 2014
22
Hello, i have A10-7850K CPU, Asus A88XM-Plus/CSM MoBo & G.Skill Sniper 2133MHz 8GB 11-11-11-30 / 1.6v RAM, CPU works at 4.2Ghz, freq 100Mhz, multiplier x42, 1.350v,
MoBo supports 2400Mhz RAM oc, can i try to overclock my ram?
I want to try changing freq to 2400MHz, cas to 11-13-13-31 and voltage to 1.65v is it safe?
Thank you.
Yes, you can definitely give it a shot. Don't forget to input CPU-NB Voltage to stabilize the memory controller. Without setting the precise value, the system will be unstable.
Thank you
GSKILL SUPPORT
