Noticed today that after gaming, running benchmarks/stress tests that my individual cores were good, however package and cpu temps would not go back down and reflect the low temps of the cores in HWMonitor. I changed windows power setting to balanced, voltages stayed in the 1.2-1.37 range and still would not lower.
I moved onto task manager to see what was happening and I found that the mentioned software was eating up my cpu, I closed the software and boom issue resolved.
I would like the ability to control the colors on this ram (for the record I only purchased this kit trident z 32gig 2x16 because it was highest rated and best price on newegg) I dont so much care about having rgb but I would like the option if i choose. Are there any known fixes for this? Will it cause damage to the memory if i have to constantly open and close the program to re-write the color profile?
Note: this is not the only software I have issues with either - I can not run Corsair ICUE as it causes strange stuttering at all times. I can not find a solution to this problem either.
system specs -
i7 9700kf
NH D15s
RTX 2080
g.skill trident z rgb 32gb 2x16
z390 pro 4 mobo
it is the PowerSpec g433, but I made some minor changes with the cooler and RAM. All in all I am happy with the build, will eventually upgrade the mobo and psu but I figure I'll just run with them until I find they no longer suit their purpose.
system specs -
i7 9700kf
NH D15s
RTX 2080
z390 pro 4 mobo
