Question G.Skill Trident Z5 DDR5 D.O.C.P. / Overclocking Advice ?
EatYoVegetablez
Commendable
Oct 19, 2022
Hi! I recently built a new PC with these specs:
CPU: AMD Ryzen 9 7950x
GPU: Nvidia RTX 3080ti Founder's Edition
Motherboard: Asus ROG CROSSHAIR X670E HERO
Memory: G.SKILL Trident Z5 RGB Series 64GB (2 x 32GB) F5-6000J3040G32GX2-TZ5RK Timing 30-40-40-96
PSU: Corsair HX1200 Platinum 1200 W
CPU Cooler: Noctua NH-D15
OS: Windows 11 Home
Everything is working great so far, having had it for about 2 weeks now, but I have been having issues getting my D.O.C.P. preset to work, and I'm not very well versed in fixing issues with memory overclocking as I have previously used Intel CPUs and never had trouble with XMP presets.
Whenever I change my BIOS settings to D.O.C.P. my PC blue screens on restart with the error code 0xc0000428 saying that the digital signature for this file couldn't be verified (pictures included). I've run Windows Memory Diagnostic and it came back with no issues, so I'm hoping that my memory itself is fine, and it runs fine at the default 4800MHz.
The settings that change from [Auto] with D.O.C.P. are as follows:
  • Ai Overclock Tuner -> D.O.C.P.
  • Memory Frequency -> DDR5-6000MHz
  • DRAM CAS# Latency -> 30
  • DRAM RAS# to CAS# Delay -> 40
  • DRAM RAS# PRE Time -> 40
  • DRAM RAS# ACT Time -> 96
  • DRAM VDD Voltage -> 1.40000
  • DRAM VDDQ Voltage 1.40000
  • PMIC Voltages -> Sync All PMICs
From what I could find about this specific memory online, there may be something about the voltages that I could change, but I'm wary of harming anything by changing it because of the cost of the build 😅 (I'm a video editor so this is my work PC)
If anyone has any help they could offer it would be much appreciated, and I'm sorry if I come off as an idiot, I have a lot to learn here! If there is any other information that would be helpful, please let me know! Thanks for reading my post!
Pictures: View: https://imgur.com/a/bsN8CRO
That memory kit is not compatible with that motherboard based on G.Skill's own memory configurator.
You need to return that kit and get one that is validated as compatible by G.Skill. There are five similar kits listed on that page.
Ahhh I see, I wasn't able to find my motherboard on that configurator when I was purchasing so it must have been updated later :/ thanks!
